Roles and Permissions Support¶
You can add/edit roles and permission for users. A role is just a group of users with some pre-defined permissions, you can toggle user roles in user list page at admin panel.
role_quota is used to set quota for a certain role of users, the smallest unit supported by role_quota is mb. For example, we can set the quota of employee to 100G by adding 'role_quota': '100g', and leave other role of users to the default quota.
can_add_public_repo is to set whether a role can create a public library, default is "False". Note:The can_add_public_repo option will not take effect if you configure global CLOUD_MODE = True.
The storage_ids permission is used for assigning storage backends to users with specific role. More details can be found in multiple storage backends.
Since version 10.0, upload_rate_limit and download_rate_limit are added to limit upload and download speed for users with different roles. After configured the rate limit, run the following command in the seafile-server-latest directory to make the configuration take effect:
./seahub.sh python-env python3 seahub/manage.py set_user_role_upload_download_rate_limit
Since version 11.0.9 pro, can_share_repo is added to limit users' ability to share a library.
Seafile comes with two build-in roles default and guest, a default user is a normal user with permissions as followings:
'default': {
'can_add_repo': True,
'can_share_repo': True,
'can_add_group': True,
'can_view_org': True,
'can_add_public_repo': False,
'can_use_global_address_book': True,
'can_generate_share_link': True,
'can_generate_upload_link': True,
'can_send_share_link_mail': True,
'can_invite_guest': False,
'can_connect_with_android_clients': True,
'can_connect_with_ios_clients': True,
'can_connect_with_desktop_clients': True,
'storage_ids': [],
'role_quota': '',
'can_publish_repo': True,
'upload_rate_limit': 0, # unit: kb/s
'download_rate_limit': 0,
While a guest user can only read files/folders in the system, here are the permissions for a guest user:
'guest': {
'can_add_repo': False,
'can_share_repo': False,
'can_add_group': False,
'can_view_org': False,
'can_use_global_address_book': False,
'can_generate_share_link': False,
'can_generate_upload_link': False,
'can_send_share_link_mail': False,
'can_connect_with_android_clients': False,
'can_connect_with_ios_clients': False,
'can_connect_with_desktop_clients': False,
'storage_ids': [],
'role_quota': '',
'can_publish_repo': False,
Edit build-in roles¶
If you want to edit the permissions of build-in roles, e.g. default users can invite guest, guest users can view repos in organization, you can add following lines to seahub_settings.py with corresponding permissions set to True.
ENABLED_ROLE_PERMISSIONS = {
'default': {
'can_invite_guest': True,
'storage_ids': [],
'role_quota': '',
'upload_rate_limit': 2000, # unit: kb/s
'download_rate_limit': 4000,
'guest': {
'storage_ids': [],
'role_quota': '',
'upload_rate_limit': 100,
'download_rate_limit': 200,
More about guest invitation feature¶
An user who has can_invite_guest permission can invite people outside of the organization as guest.
In order to use this feature, in addition to granting can_invite_guest permission to the user, add the following line to seahub_settings.py,
ENABLE_GUEST_INVITATION = True
# invitation expire time
INVITATIONS_TOKEN_AGE = 72 # hours
After restarting, users who have can_invite_guest permission will see "Invite People" section at sidebar of home page.
Users can invite a guest user by providing his/her email address, system will email the invite link to the user.
Tip: If you want to block certain email addresses for the invitation, you can define a blacklist, e.g.
INVITATION_ACCEPTER_BLACKLIST = ["a@a.com", "*@a-a-a.com", r".*@(foo|bar).com", ]
After that, email address "a@a.com", any email address ends with "@a-a-a.com" and any email address ends with "@foo.com" or "@bar.com" will not be allowed.
Add custom roles¶
If you want to add a new role and assign some users with this role, e.g. new role employee can invite guest and can create public library and have all other permissions a default user has, you can add following lines to seahub_settings.py
'default': {
'storage_ids': [],
'role_quota': '',
'guest': {
'storage_ids': [],
'role_quota': '',
'employee': {
'can_add_public_repo': True,
'storage_ids': [],
'role_quota': '',
'upload_rate_limit': 500,
'download_rate_limit': 800,
