Setup Memcached Cluster and MariaDB Galera Cluster¶
For high availability, it is recommended to set up a memcached cluster and MariaDB Galera cluster for Seafile cluster. This documentation will provide information on how to do this with 3 servers. You can either use 3 dedicated servers or use the 3 Seafile server nodes.
Setup Memcached Cluster¶
Seafile servers share session information within memcached. So when you set up a Seafile cluster, there needs to be a memcached server (cluster) running.
The simplest way is to use a single-node memcached server. But when this server fails, some functions in the web UI of Seafile cannot work. So for HA, it's usually desirable to have more than one memcached servers.
We recommend to setup two independent memcached servers, in active/standby mode. A floating IP address (or Virtual IP address in some context) is assigned to the current active node. When the active node goes down, Keepalived will migrate the virtual IP to the standby node. So you actually use a single node memcahced, but use Keepalived (or other alternatives) to provide high availability.
After installing memcahced on each server, you need to make some modification to the memcached config file.
# Under Ubuntu
vi /etc/memcached.conf
# Start with a cap of 64 megs of memory. It's reasonable, and the daemon default
# Note that the daemon will grow to this size, but does not start out holding this much
# memory
# -m 64
-m 256
# Specify which IP address to listen on. The default is to listen on all IP addresses
# This parameter is one of the only security measures that memcached has, so make sure
# it's listening on a firewalled interface.
-l 0.0.0.0
service memcached restart
NOTE: Please configure memcached to start on system startup.
Install and configure Keepalived.
# For Ubuntu
sudo apt-get install keepalived -y
Modify keepalived config file /etc/keepalived/keepalived.conf.
On active node
cat /etc/keepalived/keepalived.conf
! Configuration File for keepalived
global_defs {
notification_email {
root@localhost
notification_email_from keepalived@localhost
smtp_server 127.0.0.1
smtp_connect_timeout 30
router_id node1
vrrp_mcast_group4 224.0.100.19
vrrp_script chk_memcached {
script "killall -0 memcached && exit 0 || exit 1"
interval 1
weight -5
vrrp_instance VI_1 {
state MASTER
interface ens33
virtual_router_id 51
priority 100
advert_int 1
authentication {
auth_type PASS
auth_pass hello123
virtual_ipaddress {
192.168.1.113/24 dev ens33
track_script {
chk_memcached
On standby node
global_defs {
root@localhost
router_id node2
interval 1
weight -5
state BACKUP
interface ens33
priority 98
advert_int 1
authentication {
auth_type PASS
auth_pass hello123
virtual_ipaddress {
track_script {
chk_memcached
NOTE: Please adjust the network device names accordingly. virtual_ipaddress is the floating IP address in use.
Setup MariaDB Cluster¶
MariaDB cluster helps you to remove single point of failure from the cluster architecture. Every update in the database cluster is synchronously replicated to all instances.
You can choose between two different setups:
- For a small cluster with 3 nodes, you can run MariaDB cluster directly on the Seafile server nodes. Each Seafile server access its local instance of MariaDB.
- For larger clusters, it's preferable to have 3 dedicated MariaDB nodes to form a cluster. You have to set up a HAProxy in front of the MariaDB cluster. Seafile will access database via HAProxy.
We refer to the documentation from MariaDB team:
- Setting up MariaDB cluster on CentOS 7
- Setting up HAProxy for MariaDB Galera Cluster. Note that Seafile doesn't use read/write isolation techniques. So you don't need to setup read and write pools.
