Skip to content
Configure Seafile Pro Edition to use LDAP
How does LDAP User Management work in Seafile
When Seafile is integrated with LDAP, users in the system can be divided into two tiers:
  • Users within Seafile's internal user database. Some attributes are attached to these users, such as whether it's a system admin user, whether it's activated.
  • Users in LDAP server. These are all the intended users of Seafile inside the LDAP server. Seafile doesn't manipulate these users directly. It has to import them into its internal database before setting attributes on them.
When Seafile counts the number of users in the system, it only counts the activated users in its internal database.
Basic LDAP Integration
The only requirement for Seafile to use LDAP for authentication is that there must be a unique identifier for each user in the LDAP server. This id should also be user-friendly as the users will use it as username when login. Below are some usual options for this unique identifier:
  • Email address: this is the most common choice. Most organizations assign unique email address for each member.
  • UserPrincipalName: this is a user attribute only available in Active Directory. It's format is user-login-name@domain-name, e.g. john@example.com. It's not a real email address, but it works fine as the unique identifier.
Note, the identifier is stored in table social_auth_usersocialauth to map the identifier to internal user ID in Seafile. When this ID is changed in LDAP for a user, you only need to update social_auth_usersocialauth table.
Integration Configuration
Add the following options to seahub_settings.py. Examples are as follows:
ENABLE_LDAP = True
LDAP_SERVER_URL = 'ldap://192.168.0.1'
LDAP_BASE_DN = 'ou=test,dc=seafile,dc=ren'
LDAP_ADMIN_DN = 'administrator@example.com'
LDAP_ADMIN_PASSWORD = 'yourpassword'
LDAP_PROVIDER = 'ldap'
LDAP_LOGIN_ATTR = 'email'
LDAP_CONTACT_EMAIL_ATTR = ''
LDAP_USER_ROLE_ATTR = ''
LDAP_USER_FIRST_NAME_ATTR = 'givenName'
LDAP_USER_LAST_NAME_ATTR = 'sn'
LDAP_USER_NAME_REVERSE = False
LDAP_FILTER = 'memberOf=CN=testgroup,OU=test,DC=seafile,DC=ren'
Meaning of some options:
  • LDAP_SERVER_URL: The URL of LDAP server
  • LDAP_BASE_DN:The root node of users who can log in to Seafile in the LDAP server
  • LDAP_ADMIN_DN: DN of the administrator used to query the LDAP server for information. For OpenLDAP, it maybe cn=admin,dc=example,dc=com
  • LDAP_ADMIN_PASSWORD: Password of LDAP_ADMIN_DN
  • LDAP_PROVIDER: Identify the source of the user, used in the table social_auth_usersocialauth, defaults by 'ldap'
  • LDAP_LOGIN_ATTR: User's attribute used to log in to Seafile. It should be a unique identifier for the user in LDAP server. Learn more about this id from the descriptions at begining of this section.
  • LDAP_CONTACT_EMAIL_ATTR: LDAP user's contact_email attribute. It will be stored as a user's contact email in Seafile.
  • LDAP_USER_ROLE_ATTR: LDAP user's role attribute
  • LDAP_USER_FIRST_NAME_ATTR: Attribute for user's first name. It's "givenName" by default.
  • LDAP_USER_LAST_NAME_ATTR: Attribute for user's last name. It's "sn" by default.
  • LDAP_USER_NAME_REVERSE: In some languages, such as Chinese, the display order of the first and last name is reversed. Set this option if you need it.
  • LDAP_FILTER: Additioinal filter conditions. Users who meet the filter conditions can log in , otherwise they cannot log in.
Tips for choosing LDAP_BASE_DN and LDAP_ADMIN_DN:
  • To determine the LDAP_BASE_DN, you first have to navigate your organization hierachy on the domain controller GUI.
    • If you want to allow all users to use Seafile, you can use cn=users,dc=yourdomain,dc=com as LDAP_BASE_DN (with proper adjustment for your own needs).
    • If you want to limit users to a certain OU (Organization Unit), you run dsquery command on the domain controller to find out the DN for this OU. For example, if the OU is staffs, you can run dsquery ou -name staff. More information can be found here.
  • AD supports user@domain.name format for the LDAP_ADMIN_DN option. For example you can use administrator@example.com for LDAP_ADMIN_DN. Sometime the domain controller doesn't recognize this format. You can still use dsquery command to find out user's DN. For example, if the user name is 'seafileuser', run dsquery user -name seafileuser. More information here.
Setting Up LDAP User Sync (optional)
In Seafile Pro, except for importing users into internal database when they log in, you can also configure Seafile to periodically sync user information from LDAP server into the internal database.
User's full name, department and contact email address can be synced to internal database. Users can use this information to more easily search for a specific user. User's Windows or Unix login id can be synced to the internal database. This allows the user to log in with its familiar login id. When a user is removed from LDAP, the corresponding user in Seafile will be deactivated. Otherwise, he could still sync files with Seafile client or access the web interface. After synchronization is complete, you can see the user's full name, department and contact email on its profile page.
Sync configuration items
# Basic configuration items
ENABLE_LDAP = True
# ldap user sync options.
LDAP_SYNC_INTERVAL = 60
ENABLE_LDAP_USER_SYNC = True
LDAP_USER_OBJECT_CLASS = 'person'
LDAP_DEPT_ATTR = ''
LDAP_UID_ATTR = ''
LDAP_AUTO_REACTIVATE_USERS = True
LDAP_USE_PAGED_RESULT = False
IMPORT_NEW_USER = True
ACTIVATE_USER_WHEN_IMPORT = True
DEACTIVE_USER_IF_NOTFOUND = False
ENABLE_EXTRA_USER_INFO_SYNC = True
  • LDAP_SYNC_INTERVAL: The interval to sync. Unit is minutes. Defaults to 60 minutes.
  • ENABLE_LDAP_USER_SYNC: set to "true" if you want to enable ldap user synchronization
  • LDAP_USER_OBJECT_CLASS: This is the name of the class used to search for user objects. In Active Directory, it's usually "person". The default value is "person".
  • LDAP_DEPT_ATTR: Attribute for depatment info.
  • LDAP_UID_ATTR: Attribute for Windows login name. If this is synchronized, users can also log in with their Windows login name. In AD, the attribute sAMAccountName can be used as UID_ATTR. The attribute will be stored as login_id in Seafile (in seahub_db.profile_profile table).
  • LDAP_AUTO_REACTIVATE_USERS: Whether to auto activate deactivated user, default by 'False'
  • LDAP_USE_PAGED_RESULT: Whether to use pagination extension.It is useful when you have more than 1000 users in LDAP server.
  • IMPORT_NEW_USER: Whether to import new users when sync user.
  • ACTIVE_USER_WHEN_IMPORT: Whether to activate the user automatically when imported.
  • DEACTIVE_USER_IF_NOTFOUND: set to "true" if you want to deactivate a user when he/she was deleted in AD server.
  • ENABLE_EXTRA_USER_INFO_SYNC: Enable synchronization of additional user information, including user's full name, department, and Windows login name, etc.
Importing Users without Activating Them
The users imported with the above configuration will be activated by default. For some organizations with large number of users, they may want to import user information (such as user full name) without activating the imported users. Activating all imported users will require licenses for all users in LDAP, which may not be affordable.
Seafile provides a combination of options for such use case. You can modify below option in seahub_settings.py:
ACTIVATE_USER_WHEN_IMPORT = False
This prevents Seafile from activating imported users. Then, add below option to seahub_settings.py:
ACTIVATE_AFTER_FIRST_LOGIN = True
This option will automatically activate users when they login to Seafile for the first time.
Reactivating Users
When you set the DEACTIVE_USER_IF_NOTFOUND option, a user will be deactivated when he/she is not found in LDAP server. By default, even after this user reappears in the LDAP server, it won't be reactivated automatically. This is to prevent auto reactivating a user that was manually deactivated by the system admin.
However, sometimes it's desirable to auto reactivate such users. You can modify below option in seahub_settings.py:
Manually Trigger Synchronization
To test your LDAP sync configuration, you can run the sync command manually.
To trigger LDAP sync manually:
cd seafile-server-latest
./pro/pro.py ldapsync
For Seafile Docker
docker exec -it seafile /opt/seafile/seafile-server-latest/pro/pro.py ldapsync
Setting Up LDAP Group Sync (optional)
How It Works
The importing or syncing process maps groups from LDAP directory server to groups in Seafile's internal database. This process is one-way.
  • Any changes to groups in the database won't propagate back to LDAP;
  • Any changes to groups in the database, except for "setting a member as group admin", will be overwritten in the next LDAP sync operation. If you want to add or delete members, you can only do that on LDAP server.
  • The creator of imported groups will be set to the system admin.
There are two modes of operation:
  • Periodical: the syncing process will be executed in a fixed interval
  • Manual: there is a script you can run to trigger the syncing once
Configuration
Before enabling LDAP group sync, you should have configured LDAP authentication. See Basic LDAP Integration for details.
The following are LDAP group sync related options:
# ldap group sync options.
ENABLE_LDAP_GROUP_SYNC = True            # Whether to enable group sync
LDAP_GROUP_OBJECT_CLASS = 'group'        # This is the name of the class used to search for group objects.
LDAP_GROUP_MEMBER_ATTR = 'member'        # The attribute field to use when loading the group's members.
                                         # For most directory servers, the attributes is "member"
                                         # which is the default value.For "posixGroup", it should be set to "memberUid".
LDAP_USER_ATTR_IN_MEMBERUID = 'uid'      # The user attribute set in 'memberUid' option,
                                         # which is used in "posixGroup".The default value is "uid".
LDAP_GROUP_UUID_ATTR = 'objectGUID'      # Used to uniquely identify groups in LDAP
LDAP_GROUP_FILTER = ''                   # An additional filter to use when searching group objects.
                                         # If it's set, the final filter used to run search is "(&(objectClass=GROUP_OBJECT_CLASS)(GROUP_FILTER))";
                                         # otherwise the final filter would be "(objectClass=GROUP_OBJECT_CLASS)".
LDAP_USE_GROUP_MEMBER_RANGE_QUERY = False   # When a group contains too many members,
                                         # AD will only return part of them. Set this option to TRUE
                                         # to make LDAP sync work with large groups.
DEL_GROUP_IF_NOT_FOUND = False           # Set to "true", sync process will delete the group if not found it in LDAP server.
LDAP_SYNC_GROUP_AS_DEPARTMENT = False    # Whether to sync groups as top-level departments in Seafile.
                                         # Learn more about departments in Seafile [here](https://help.seafile.com/sharing_collaboration/departments/).
LDAP_DEPT_NAME_ATTR = ''                 # Used to get the department name.
  • ENABLE_LDAP_GROUP_SYNC: Whether to enable group sync.
  • LDAP_GROUP_OBJECT_CLASS: This is the name of the class used to search for group objects.
  • LDAP_GROUP_MEMBER_ATTR: The attribute field to use when loading the group's members. For most directory servers, the attributes is "member" which is the default value.For "posixGroup", it should be set to "memberUid".
  • LDAP_USER_ATTR_IN_MEMBERUID: The user attribute set in 'memberUid' option, which is used in "posixGroup".The default value is "uid".
  • LDAP_GROUP_UUID_ATTR: Used to uniquely identify groups in LDAP
  • LDAP_GROUP_FILTER: An additional filter to use when searching group objects. If it's set, the final filter used to run search is (&(objectClass=GROUP_OBJECT_CLASS)(GROUP_FILTER)); otherwise the final filter would be (objectClass=GROUP_OBJECT_CLASS).
  • LDAP_USER_GROUP_MEMBER_RANGE_QUERY: When a group contains too many members, AD will only return part of them. Set this option to TRUE to make LDAP sync work with large groups.
  • DEL_GROUP_IF_NOT_FOUND: Set to "true", sync process will delete the group if not found it in LDAP server.
  • LDAP_SYNC_GROUP_AS_DEPARTMENT: Whether to sync groups as top-level departments in Seafile. Learn more about departments in Seafile here.
  • LDAP_DEPT_NAME_ATTR: Used to get the department name.
Note:
  • The search base for groups is the option LDAP_BASE_DN.
  • Some LDAP server, such as Active Directory, allows a group to be a member of another group. This is called "group nesting". If we find a nested group B in group A, we should recursively add all the members from group B into group A. And group B should still be imported a separate group. That is, all members of group B are also members in group A.
  • In some LDAP server, such as OpenLDAP, it's common practice to use Posix groups to store group membership. To import Posix groups as Seafile groups, set LDAP_GROUP_OBJECT_CLASS option to posixGroup. A posixGroup object in LDAP usually contains a multi-value attribute for the list of member UIDs. The name of this attribute can be set with the LDAP_GROUP_MEMBER_ATTR option. It's MemberUid by default. The value of the MemberUid attribute is an ID that can be used to identify a user, which corresponds to an attribute in the user object. The name of this ID attribute is usually uid, but can be set via the LDAP_USER_ATTR_IN_MEMBERUID option. Note that posixGroup doesn't support nested groups.
Sync OU as Departments
A department in Seafile is a special group. In addition to what you can do with a group, there are two key new features for departments:
  • Department supports hierarchy. A department can have any levels of sub-departments.
  • Department can have storage quota.
Seafile supports syncing OU (Organizational Units) from AD/LDAP to departments. The sync process keeps the hierarchical structure of the OUs.
Options for syncing departments from OU:
LDAP_SYNC_DEPARTMENT_FROM_OU = True      # Whether to enable sync departments from OU.
LDAP_DEPT_NAME_ATTR = 'description'      # Used to get the department name.
LDAP_CREATE_DEPARTMENT_LIBRARY = False   # If you decide to sync the group as a department,
                                         # you can set this option to "true". In this way, when
                                         # the group is synchronized for the first time, a library
                                         # is automatically created for the department, and the
                                         # library's name is the department's name.
LDAP_DEPT_REPO_PERM = 'rw'               # Set the permissions of the department repo, default permission is 'rw'.
LDAP_DEFAULT_DEPARTMENT_QUOTA = -2       # You can set a default space quota for each department
                                         # when you synchronize a group for the first time. The
                                         # quota is set to unlimited if this option is not set.
                                         # Unit is MB.
DEL_DEPARTMENT_IF_NOT_FOUND = False      # Set to "true", sync process will deleted the department if not found it in LDAP server.
Periodical and Manual Sync
Periodical sync won't happen immediately after you restart seafile server. It gets scheduled after the first sync interval. For example if you set sync interval to 30 minutes, the first auto sync will happen after 30 minutes you restarts. To sync immediately, you need to manually trigger it.
After the sync is run, you should see log messages like the following in logs/seafevents.log. And you should be able to see the groups in system admin page.
[2023-03-30 18:15:05,109] [DEBUG] create group 1, and add dn pair CN=DnsUpdateProxy,CN=Users,DC=Seafile,DC=local<->1 success.
[2023-03-30 18:15:05,145] [DEBUG] create group 2, and add dn pair CN=Domain Computers,CN=Users,DC=Seafile,DC=local<->2 success.
[2023-03-30 18:15:05,154] [DEBUG] create group 3, and add dn pair CN=Domain Users,CN=Users,DC=Seafile,DC=local<->3 success.
[2023-03-30 18:15:05,164] [DEBUG] create group 4, and add dn pair CN=Domain Admins,CN=Users,DC=Seafile,DC=local<->4 success.
[2023-03-30 18:15:05,176] [DEBUG] create group 5, and add dn pair CN=RAS and IAS Servers,CN=Users,DC=Seafile,DC=local<->5 success.
[2023-03-30 18:15:05,186] [DEBUG] create group 6, and add dn pair CN=Enterprise Admins,CN=Users,DC=Seafile,DC=local<->6 success.
[2023-03-30 18:15:05,197] [DEBUG] create group 7, and add dn pair CN=dev,CN=Users,DC=Seafile,DC=local<->7 success.
To trigger LDAP sync manually,
For Seafile Docker
Advanced LDAP Integration Options
Multiple BASE
Multiple base DN is useful when your company has more than one OUs to use Seafile. You can specify a list of base DN in the LDAP_BASE_DN option. The DNs are separated by ";", e.g.
LDAP_BASE_DN = 'ou=developers,dc=example,dc=com;ou=marketing,dc=example,dc=com'
Additional Search Filter
Search filter is very useful when you have a large organization but only a portion of people want to use Seafile. The filter can be given by setting LDAP_FILTER option. The value of this option follows standard LDAP search filter syntax (https://msdn.microsoft.com/en-us/library/aa746475(v=vs.85).aspx).
The final filter used for searching for users is (&($LOGIN_ATTR=*)($LDAP_FILTER)). $LOGIN_ATTR and $LDAP_FILTER will be replaced by your option values.
For example, add below option to seahub_settings.py:
LDAP_FILTER = 'memberOf=CN=group,CN=developers,DC=example,DC=com'
The final search filter would be (&(mail=*)(memberOf=CN=group,CN=developers,DC=example,DC=com))
Note that the case of attribute names in the above example is significant. The memberOf attribute is only available in Active Directory.
Limiting Seafile Users to a Group in Active Directory
You can use the LDAP_FILTER option to limit user scope to a certain AD group.
  1. First, you should find out the DN for the group. Again, we'll use the dsquery command on the domain controller. For example, if group name is 'seafilegroup', run dsquery group -name seafilegroup.
  2. Add below option to seahub_settings.py:
LDAP_FILTER = 'memberOf={output of dsquery command}'
Using TLS connection to LDAP server
If your LDAP service supports TLS connections, you can configure LDAP_SERVER_URL as the access address of the ldaps protocol to use TLS to connect to the LDAP service, for example:
LDAP_SERVER_URL = 'ldaps://192.168.0.1:636/'
Use paged results extension
LDAP protocol version 3 supports "paged results" (PR) extension. When you have large number of users, this option can greatly improve the performance of listing users. Most directory server nowadays support this extension.
In Seafile Pro Edition, add this option to seahub_settings.py to enable PR:
LDAP_USE_PAGED_RESULT = True
Follow referrals
Seafile Pro Edition supports auto following referrals in LDAP search. This is useful for partitioned LDAP or AD servers, where users may be spreaded on multiple directory servers. For more information about referrals, you can refer to this article.
To configure, add below option to seahub_settings.py, e.g.:
LDAP_FOLLOW_REFERRALS = True
Configure Multi-ldap Servers
Seafile Pro Edition supports multi-ldap servers, you can configure two ldap servers to work with seafile. Multi-ldap servers mean that, when get or search ldap user, it will iterate all configured ldap servers until a match is found; When listing all ldap users, it will iterate all ldap servers to get all users; For Ldap sync it will sync all user/group info in all configured ldap servers to seafile.
Currently, only two LDAP servers are supported.
If you want to use multi-ldap servers, please replace LDAP in the options with MULTI_LDAP_1, and then add them to seahub_settings.py, for example:
# Basic config options
ENABLE_LDAP = True
# Multi ldap config options
ENABLE_MULTI_LDAP_1 = True
MULTI_LDAP_1_SERVER_URL = 'ldap://192.168.0.2'
MULTI_LDAP_1_BASE_DN = 'ou=test,dc=seafile,dc=top'
MULTI_LDAP_1_ADMIN_DN = 'administrator@example.top'
MULTI_LDAP_1_ADMIN_PASSWORD = 'Hello@123'
MULTI_LDAP_1_PROVIDER = 'ldap1'
MULTI_LDAP_1_LOGIN_ATTR = 'userPrincipalName'
# Optional configs
MULTI_LDAP_1_USER_FIRST_NAME_ATTR = 'givenName'
MULTI_LDAP_1_USER_LAST_NAME_ATTR = 'sn'
MULTI_LDAP_1_USER_NAME_REVERSE = False
ENABLE_MULTI_LDAP_1_EXTRA_USER_INFO_SYNC = True
MULTI_LDAP_1_FILTER = 'memberOf=CN=testgroup,OU=test,DC=seafile,DC=ren'
MULTI_LDAP_1_USE_PAGED_RESULT = False
MULTI_LDAP_1_FOLLOW_REFERRALS = True
ENABLE_MULTI_LDAP_1_USER_SYNC = True
ENABLE_MULTI_LDAP_1_GROUP_SYNC = True
MULTI_LDAP_1_SYNC_DEPARTMENT_FROM_OU = True
MULTI_LDAP_1_USER_OBJECT_CLASS = 'person'
MULTI_LDAP_1_DEPT_ATTR = ''
MULTI_LDAP_1_UID_ATTR = ''
MULTI_LDAP_1_CONTACT_EMAIL_ATTR = ''
MULTI_LDAP_1_USER_ROLE_ATTR = ''
MULTI_LDAP_1_AUTO_REACTIVATE_USERS = True
MULTI_LDAP_1_GROUP_OBJECT_CLASS = 'group'
MULTI_LDAP_1_GROUP_FILTER = ''
MULTI_LDAP_1_GROUP_MEMBER_ATTR = 'member'
MULTI_LDAP_1_GROUP_UUID_ATTR = 'objectGUID'
MULTI_LDAP_1_CREATE_DEPARTMENT_LIBRARY = False
MULTI_LDAP_1_DEPT_REPO_PERM = 'rw'
MULTI_LDAP_1_DEFAULT_DEPARTMENT_QUOTA = -2
MULTI_LDAP_1_SYNC_GROUP_AS_DEPARTMENT = False
MULTI_LDAP_1_USE_GROUP_MEMBER_RANGE_QUERY = False
MULTI_LDAP_1_USER_ATTR_IN_MEMBERUID = 'uid'
MULTI_LDAP_1_DEPT_NAME_ATTR = ''
Note: There are still some shared config options are used for all LDAP servers, as follows:
# Common user sync options
IMPORT_NEW_USER = True                   # Whether to import new users when sync user
ACTIVATE_USER_WHEN_IMPORT = True         # Whether to activate the user when importing new user
DEACTIVE_USER_IF_NOTFOUND = False        # Set to "true" if you want to deactivate a user
                                         # when he/she was deleted in AD server.
# Common group sync options
SSO and LDAP users use the same uid
If you sync users from LDAP to Seafile, when the user login via SSO (ADFS or OAuth), you want Seafile to find the existing account for this user instead of creating a new one, you can set SSO_LDAP_USE_SAME_UID = True:
Note, here the UID means the unique user ID, in LDAP it is the attribute you use for LDAP_LOGIN_ATTR (not LDAP_UID_ATTR), in ADFS it is uid attribute. You need make sure you use the same attribute for the two settings.
Importing Roles from LDAP
Seafile Pro Edition supports syncing roles from LDAP or Active Directory.
To enable this feature, add below option to seahub_settings.py, e.g.
LDAP_USER_ROLE_ATTR = 'title'
LDAP_USER_ROLE_ATTR is the attribute field to configure roles in LDAP. You can write a custom function to map the role by creating a file seahub_custom_functions.py under conf/ and edit it like:
# -*- coding: utf-8 -*-
# The AD roles attribute returns a list of roles (role_list).
# The following function use the first entry in the list.
def ldap_role_mapping(role):
    if 'staff' in role:
        return 'Staff'
    if 'guest' in role:
        return 'Guest'
    if 'manager' in role:
        return 'Manager'
# From version 11.0.11-pro, you can define the following function
# to calculate a role from the role_list.
def ldap_role_list_mapping(role_list):
    if not role_list:
        return ''
    for role in role_list:
        if 'staff' in role:
            return 'Staff'
        if 'guest' in role:
            return 'Guest'
            return 'Manager'
Note: You should only define one of the two functions.
You can rewrite the function (in python) to make your own mapping rules. If the file or function doesn't exist, the first entry in role_list will be synced.
