Deploy ClamAV with Seafile¶
Use Clamav with Docker based deployment¶
Add Clamav to docker-compose.yml¶
The following section needs to be added to docker-compose.yml in the services section
av:
image: clamav/clamav:latest
container_name: seafile-clamav
networks:
- seafile-net
Modify seafile.conf¶
Add this to seafile.conf
[virus_scan]
scan_command = clamdscan
virus_code = 1
nonvirus_code = 0
scan_interval = 5
scan_size_limit = 20
threads = 2
Restart docker container¶
docker compose down
docker compose up -d
Wait some minutes until Clamav finished initializing.
Now Clamav can be used.
Use ClamAV in binary based deployment¶
Install clamav-daemon & clamav-freshclam¶
apt-get install clamav-daemon clamav-freshclam
You should run Clamd with a root permission to scan any files.
Edit the conf /etc/clamav/clamd.conf,change the following line:
LocalSocketGroup root
User root
Start the clamav-daemon¶
systemctl start clamav-daemon
- Test the software
$ curl https://secure.eicar.org/eicar.com.txt | clamdscan -
The output must include:
stream: Eicar-Test-Signature FOUND
