Skip to content
Set up logrotate for server
How it works
seaf-server support reopenning logfiles by receiving a SIGUR1 signal.
This feature is very useful when you need cut logfiles while you don't want to shutdown the server. All you need to do now is cutting the logfile on the fly.
Default logrotate configuration directory
For Debian, the default directory for logrotate should be /etc/logrotate.d/
Sample configuration
Assuming your seaf-server's logfile is setup to /opt/seafile/logs/seafile.log and your seaf-server's pidfile is setup to /opt/seafile/pids/seaf-server.pid:
The configuration for logrotate could be like this:
/opt/seafile/logs/seahub.log
/opt/seafile/logs/seafdav.log
/opt/seafile/logs/fileserver-access.log
/opt/seafile/logs/fileserver-error.log
/opt/seafile/logs/fileserver.log
/opt/seafile/logs/file_updates_sender.log
/opt/seafile/logs/repo_old_file_auto_del_scan.log
/opt/seafile/logs/seahub_email_sender.log
/opt/seafile/logs/index.log
        daily
        missingok
        rotate 7
        # compress
        # delaycompress
        dateext
        dateformat .%Y-%m-%d
        notifempty
        # create 644 root root
        sharedscripts
        postrotate
                if [ -f /opt/seafile/pids/seaf-server.pid ]; then
                        kill -USR1 `cat /opt/seafile/pids/seaf-server.pid`
                fi
                if [ -f /opt/seafile/pids/fileserver.pid ]; then
                        kill -USR1 `cat /opt/seafile/pids/fileserver.pid`
                fi
                if [ -f /opt/seafile/pids/seahub.pid ]; then
                        kill -HUP `cat /opt/seafile/pids/seahub.pid`
                fi
                if [ -f /opt/seafile/pids/seafdav.pid ]; then
                        kill -HUP `cat /opt/seafile/pids/seafdav.pid`
                fi
                find /opt/seafile/logs/ -mtime +7 -name "*.log*" -exec rm -f {} \;
        endscript
You can save this file, in Debian for example, at /etc/logrotate.d/seafile.
